SRS restraint system malfunction light
Herbster
Sheffield,south Yorkshire, uk
Slk/2009/200
Hi I have the message SRS restraint system malfunction consult workshop. my local mechanic says I need the bit of the seatbelt that the belt clips into (the buckle). where would I buy a new one of these & can you just buy the black plastic switch bit? thanks
Yes you can buy 120
this is the name on the EPC, but I cannot tell which one.
120
A 1708600069
CATCH
LEFT
120
A 2088600369
CATCH
DRIVER'S SIDE
120
A 1708600169
CATCH
DRIVER'S SEAT
AUTOLIV
120
A 1708600869
CATCH
DRIVER'S SEAT
AUTOLIV
120
A 1708600069
CATCH
CO-DRIVER'S SIDE
120
A 2088600369
CATCH
CO-DRIVER'S SIDE
120
A 1708600069
CATCH
CO-DRIVER'S SEAT
Either a breaker or new from mercedes, I only put up the diagram to show you how the parts are listed.
H
Herbster
Slk/2009/200
Has anyone else had this problem ?? It seems there's a fault with the seat. Surely this should be a Mercedes recall if that's the case??? I found this thread on another site :
Yes same problem SRS light. The problem is the wires under the seat are two short and when seat is raised it pulls on the wires which in turn causes a short in the wires. Suggest when you do the repair raise the seat to the highest point and move all the way to the front and back to make sure all wires have some slack in them. My indy says this has been a common problem and has repaired many cars by just doing some work on the wires under the seat. But mine caused damge in the buckle. The wire harnest comes in the new buckle and is not a seperate part.
Any other 171 preface lift you might wannt to get on your knees and do the test from above to void future problems.
This Email, and any attachments, may contain non-public information and is intended solely for the individual(s) to whom it is addressed. It may contain sensitive or protectively marked material and should be handled accordingly. If this Email has been misdirected, please notify the author immediately. If you are not the intended recipient you must not disclose, distribute, copy, print or rely on any of the information contained in it or attached, and all copies must be deleted immediately. Whilst we take reasonable steps to try to identify any software viruses, any attachments to this Email may nevertheless contain viruses which our anti-virus software has failed to identify. You should therefore carry out your own anti-virus checks before opening any documents. Sheffield City Council will not accept any liability for damage caused by computer viruses emanating from any attachment or other document supplied with this e-mail
