Strange noise C63 W204
C63 w204
Hey everyone, hope you are all well. I’ve recently bought a c63 w204 2011 (61 plate). The issue it has is that it’s making a loud whining noise which increases when your revs do. It’s really annoying and I have already tried getting it sorted by replacing the power steering reservoir. My steering isn’t as heavy now but the noise is still there. I was told by the mechanic it would clear up in about 20/30 miles but this doesn’t make sense as the noise is the exact same as it was before.
Here is a video clip:
https://streamable.com/s99abj
I hope you guys can point me in the right direction.
mattkh
England
A160 W168 1999 1.6
Wheel bearing noise?
Try to pinpoint the noise, front, back, right or left.
Power steering noise is normally when turning the steering, and not affected by engine revs.
D
C63 w204
Yeah I’m at a bit of a loss, don’t have a clue what it is and I don’t even want to drive the car that’s how annoying the noise is.
ernieh
Scotland, East
Audi Q2 Sport, 2022, 1.5 Petrol
If you haven't already, I would take off the serpentine belt and check each accessory by turning the pulley. Having said that, to me that noise sounds like the alternator bearings. Typically it could decrease as the battery becomes charged and the load on the bearings reduces.
Let us know how you get on.
Ernie
D
C63 w204
Ernie
I think I also just had that belt or fan belt replaced one of the 2 can’t remember what it’s called exactly. I’ll have a listen on where the sound is coming from exactly.
D
C63 w204
I’ve had a look and from what I can hear it’s loudest near the oil cap.
mattkh
England
A160 W168 1999 1.6
One more idea. The noise could be from the Supercharger.
D
C63 w204
Unless someone's fitted a Weistec to it then I'd be surprised to say the least on an M156.
It’s deffo not that, cars completely stock lol. I’ve been told by a garage it’s a pulley, sounds about right but not sure which one.
daveenty
The Frozen North :(
2019 AMG S Class Coupe
A process of elimination now I suppose.
You could start by removing belts if you feel comfortable doing this, if not then a local independent, ideally someone who knows these cars and not just a guy who had a couple of Mercedes a few years ago.
If you post up your approximate location then I'm sure that someone will help with a recommendation.
Just as a "finally", did you buy it privately or through a dealer? If the latter then it may be prudent to let them have a look.
Ant K
Mercedes C63 AMG 2009 Estate
Hi
I had this noise earlier in the year:
Had to replace one of the pulleys and been fine since.
D
C63 w204
Hi
Quite similar to mine but mine is there all the time. Next time I get a chance I’ll open the bonnet and get a video from the engine bay.
Ant K
Can hear it a better in this second vid warmed up:
Was scary googling noises for this engine and what it could be
bembo449
gainsborough , lincolnshire
recently bought ? if less than 3 months , take it back to the seller and don't except its return till it isn't making that noise , consumers act 2015 , repair , replace , refund
D
C63 w204
  • #19
Private seller heard the noise when I bought it thinking it was the reservoir as that’s a common issue.
