Craiglxviii
- Sep 6, 2015
- Location
- Cambs UK
- 970 Panamera Turbo; W221 S500L AMG Line, C215 CL500, W251 R350L AMG Line, plus several more now gone
LostKiwi said, I thought it was the same stuff. It all seems a bit confusing. There's quite a bit of contradictory stuff on wiki but must be quite similar, as LostKiwi said its a light oil and other bits say its derived from petrol
Heat of combustion of kerosene is similar to that of diesel fuel; its lower heating value is 43.1 MJ/kg (around 18,500 Btu/lb), and its higher heating value is 46.2 MJ/kg.
JP-8, (for "Jet Propellant 8") a kerosene-based fuel, is used by the United States military as a replacement in diesel fuelled vehicles and for powering aircraft. JP-8 is also by the U.S. military and its NATO allies as a fuel for heaters, stoves, tanks and as a replacement for diesel fuel in the engines of nearly all tactical ground vehicles and electrical generators.
Yup. JP-1 through 8 are all variously interchangeable with different additives to achieve different things (freezing, flashpoints etc). JP-6 used to be the ship- standard AvTur due to its higher flashpoint for instance.
All are replaceable in an emergency with 105 octane AvGas believe it or not, but the engine life between full overhaul reduces by around 98% as a result.
