Tyre pressure on r19 cls320
Herod
London uk
Cls 320 /2006/3
Hi everyone,
I just bought a cls 320 from 2006 and is equipped with R19 tyres.
Front 255/35 ZR19 96y Falcon tyres and rear 285/30 ZR19 98y and I'd like to know what tyre pressure I should put in for both situations full car or just myself, summer or winter.
I checked MB site and I tried google it and I couldn't find a proper answer.
Thank you all in advance
whitenemesis
CLS55 AMG '05
Tyre pressures are shown on the inside of the fuel filler flap.
36/38 light load. 38/42 full load
H
Herod
London uk
Cls 320 /2006/3
Thank you for your answer but this is the firs thing that I have done
Does the chart apply only to the factory fitted tyres (only r17 and r18)?? Or I can use the chart for the R19"
Thank you for your quick replay
whitenemesis
CLS55 AMG '05
It also applies to 19"
Generally speaking tyre pressure is a function of axle weight not tyre size. The lower the tyre profile the higher (within the recommended range) pressure might be beneficial in preventing damage from potholes etc. at the expense of ride comfort and wear.
H
Herod
London uk
Cls 320 /2006/3
Thank you
b1g1an
CLS55 AMG
Says 38/41 with load on mine.
b1g1an
CLS55 AMG
That must make for a very hard ride
Never use the fully loaded settings for any car as they always make them uncomfortable.
On the other hand the v70 I used to have recommended 31 on the front for a normal load and that was so soft it felt like a damper had popped the way it moved about.
My V70r will only take 17" wheels and had 205 x 50 x 17", I have fitted 215 now and still have to use 33 to stop the tyres from bottoming out
b1g1an
CLS55 AMG
Mine had 225/45R17 and always 34 all round was best, never thought about the tyre actually bottoming out, doesn't bare thinking about with all the potholes about today.
Do you find the wheels are slightly porous, I had two v70s and both lost air quicker than you'd expect?
My wheels were fine for 8 years, then they had to be sealed,,it is corrosion between the wheel and tyre that gives the problem.
I had them re furbished last year and all fine
Biggles299
Brighton
2014 CLS SB, 2008 CLS, 1999 C Class Estate, MINI MOKE
I use 32 all round in mine (same sized wheels and tyres as yours). This is set cold, typical tyre temp 12-15 C.
That is just what I have used on my MB's for the last few years and never any problem
b1g1an
CLS55 AMG
Mine were both like that from new, had the first for two years, heap of crap that it was, and second for seven.
I have only spent £45 in the 13 years I have had mine, and always my own servicing other than a Cam belt change at 50 k
