V-Class Reverse Camera doesn't come on straight away.
SkyeLuxuryTours
2017 V250 LWB
Reverse camera in my 2017 V250 has been working perceftly until a few days ago. I reset settings to try and do something else (can't even remember what now - something simple like trying to delete all radio favourites at once!). Since then here is what is happening:
Note: I DO have the 'engage camera when R gear selected' option checked.
WHen I go into reverse: Rear camera cover opens immediately, screen goes into camera mode but no image is displayed. As soon as I slect drive gear the front camera view shows as normal. As soon as I change back into reverse the rear camera shows as normal.
In other words, to show the reverse camera view I need to go into reverse, then flick into drive, then go back into reverse. Which is a real pain!
Any advice would be very gratefully received. Thanks in advance, Stuart
Hello and welcome
I’d “uncheck” it the use it then select the option again and see if that works. Next I might even RTFM... or a hard reset on the battery
SkyeLuxuryTours
2017 V250 LWB
Thanks Blobcat - Gave that a try (unchecking then rechecking) and still the same. Then tried resseting again on the Car System Settings but no luck. Manual has nothing useful unfortunately! Thanks for help - I think I might need to take in to dealer... Actually you suggest hard reset on battery: Would that mean completely disconnecting batery then reconnecting. Is that safe enough for everything else in car? Thanks again, Stuart
