Vito 639 steering joint
Andrew Roberts
Vito 2004 2.2
Good evening,
I hope I am posting on the correct place.
Here I go.
I am planning changing the lower in on steering column,and would like some advice on how to go about it,
Would I have to release steering wheel or steering rack etc,?
The garage cannot do it in time for the 10 day retest thanks in advance
mattkh
England
A160 W168 1999 1.6
Good evening,
Here I go.
Forum members may be able to recommend some garages. Which part of the country are you in.
A
Andrew Roberts
Vito 2004 2.2
Anglesey ,north wales
mattkh
England
A160 W168 1999 1.6
Dronsfields in Oldham.
Do you have the part you want to install..?
A
Andrew Roberts
Vito 2004 2.2
Yes,I have the part
mattkh
England
A160 W168 1999 1.6
Thanks. Please put up the part number here. Thanks.
mattkh
England
A160 W168 1999 1.6
I looked up a parts catalogue for w639 Vito and looked like MBenz dont sell a UJ on its own. May be they sell the whole steering shaft. That got me thinking.
By the way, in my research, seen a utube of removing the steering shaft on a Sprinter. Very detailed it is. The airbag scares me. The steering wheel has to come off, then all the brackets securing the shaft before pulling the shaft up.
A
Andrew Roberts
Vito 2004 2.2
I already have the part.
Is the sprinter the same steering parts as Vito 639 do you know?
mattkh
England
A160 W168 1999 1.6
Pass. And unfortunately, dont know anybody I can ask.
A
Andrew Roberts
Vito 2004 2.2
Good evening all members,
I am still getting used to this forum.
So apologies in advance if you have seen it before
I have a Vito 639
It has amongst mot failure lower steering
UJointi am looking if this is fairly to do
Would whoever does ithave to remove or loosen steering rack,or steering wheelor once in clamp torx bolt would be removed,
Is it staight fareardthanks
Andy
A
Andrew Roberts
Vito 2004 2.2
Hi all,I have put another post on here,
But cannot find it,so here we go.
I had a go changing lower steering column,but top splines was the other way round,so put the old back,receiving correct one today
Anyway took the Vito for a spin
The traction control light now comes on
The column middle joint was free while trying to reconnect,
Could I have upset a steering sensor?
Any tips appreciated
Thanks for any help
A
Andrew Roberts
Vito 2004 2.2
Ah,steering was not locked,my mistake,
The other one arrived ,
How could I rectify the the light issue?
Would anyone know?
A
Andrew Roberts
Vito 2004 2.2
Oh right ,my wife was holding the wheel central
A
Andrew Roberts
Vito 2004 2.2
  • #17
Ok here's the latest on my project vito 639 111cdi
It has gone now for unexpected welding job
Like I have mentioned here before.had some issues with it
Yesterday the new lower steering column was fitted by myself
During the problem last week trying to fit the incorrect shaft ,I have affected the traction control light somehow,now comes on after moving a little and stays on
Does anyone know if this can without a scanner type tool,
Regards .andy
mattkh
England
A160 W168 1999 1.6
I thought you were having a problem with a speed sensor.
Were you able to change it..?
A
Andrew Roberts
Vito 2004 2.2
  • #19
Mattkh
Hi,oh yes that was finally sorted with Mercedes abs sensor
It's a long project now,but nearly there
Took it for a spin today,wants a goob belt up the road soon.
But just the traction control light now,welding
Was quoted £500 ish but will be around £150
Light is on because of bottom column replaced,steering moved while doing it
mattkh
England
A160 W168 1999 1.6
Right, the van is going to get some welding done.
Normally, the van battery is disconnected before doing the welding.
I reckon the traction control light will sort itself out after that, especially as the steering wheel was held in position when you were working on it.
www.W140.co.uk&www.r129.co
