w124 230 throttle linkage query
Uncle tony
Ravenshoe 4888
W124 230e 1989
Im wondering also could that lever be associated with my cruise control,,my crusie seems to work however..
DREAMER NO2
W124 2.6E M103 1989
Uncle Tony thank you for your return post .If your happy and all works well then your good to go .There were a few types may be i put up a picture for the other set up .I will look again Tony what engine do you have ?.
Uncle tony
Ravenshoe 4888
W124 230e 1989
Hi mr dreamer...its a 230e,,,and yes that pic of throttle assembly is the same,,but at the non micro switch end there is another arm around the corner..it has a up an down action i reckon this is where my missing spring should be .around the side of unit....oh i don't know mr dreamer..hehehe...i shall try to get my phone down there to take a pic it might show me where the anchor point is...have a nice day bloke....
Uncle tony
Ravenshoe 4888
W124 230e 1989
20190814_145252.jpg 20190814_145252.jpg 20190811_113021.jpg Hi mr dreamer...its a 230e,,,and yes that pic of throttle assembly is the same,,but at the non micro switch end there is another arm around the corner..it has a up an down action i reckon this is where my missing spring should be .around the side of unit....oh i don't know mr dreamer..hehehe...i shall try to get my phone down there to take a pic it might show me where the anchor point is...have a nice day bloke....
Uncle tony
Ravenshoe 4888
W124 230e 1989
Hey gday mr dreamer,,,hey i think i found it...i read a post on here days ago or more,,the fellas issue sounded like mine but his car was a 190e,,however he found the spring and where it hooks up and describes "taking oil filter out and poke your hand in there an the spring mount can be accessed ,", iv just had a look on mine 230e an its look like the same as the 190e,,,so I'm gonna take out oil filter tomorra an hopefully i will get a result,,hehehe,,,id like to have it factory again not like iv got it presently ,,,thanks
Uncle tony
Ravenshoe 4888
W124 230e 1989
M
Hi all, all the best for 2009 etc. Due off the germany in the 230TE again later in the month and finally got around to replacing the stiff accelerator cable. However, I already noticed whilst looking at the old cable in situ, to the throttle body end that a spring was missing from the bottom of the guide lever, and that in the rest position the guide lever wasnt quite touching the idle microswitch- yet the car ran fine......
so on installing the new cable I have also got hold of a spring for the guide lever, but, for adjusting the new cable haynes seems to make reference to a 'connecting lever' that 'is a flat adjustable lever that joins the guide lever to the throttle lever' but I cant see this lever on the assembly- haynes notes it is connected to the guide lever by a ball socket joint-? the only connection between the guide lever and the throttle lever on my car is the roller and L shaped cut out on the guide lever:-
So is haynes making reference to a set up not found on the 230 (fuel injected) or is my car missing components, or some misunderstanding on my part? Apologies for the long and difficult to understand post- I'm a bit stuck:confused:
,,, hello,,omg this is my issue 230e,,that little spring from that little lever, i has a tab to take a spring just as i thought,,thanks bloke,,,now pls tell me did u manage to get it mounted at the intake end,,is there somewhere obvious i can c or feel once i remove oil filter??,,,,cheers
DREAMER NO2
W124 2.6E M103 1989
Tony Please dont call me mr just dreamer will do . Dont you mean that you will need to remove the air box ,not the oil filter . Is you gearbox a manual ,?only reason that i can see your throttle linkage is different to my picture .
Uncle tony
Ravenshoe 4888
W124 230e 1989
He
Hello dreamer,,,theres a member sacco he posted a similar issue,,he mention he had to remove the oil filter to get his hand down under inside i gues near oil filter is a hidden mount for a spring,,.my car is auto...but u know what i think the 190e setup is same as mine...i think that little lever operates the throttle body butterfly..whereabouts are you in this world dreamer?, all these internet stuff is pretty good aint it,,
Uncle tony
Ravenshoe 4888
W124 230e 1989
Yessireebob,,,thats the little lever i speak of,,part 2,,,i bet that wants a spring return heading towards inlet manifold, beside the oil filter,,,,
DREAMER NO2
W124 2.6E M103 1989
Tony you know when you go to google search ? if you look to the right top of the screen you will see images click on it. Then the search box will change .You can now put any thing in the search box you need to know about --- try it out .
Uncle tony
Ravenshoe 4888
W124 230e 1989
I find number 2 in the diagram is a spring and the number is View attachment 52059 A102 993 23 10 .
Omg,,,thats gotta be it,,makes sense the style of it,,ok,,brilliant unreal,,,i read your other post for google i will try it,,i still in explore an learn with computer stuff, that spring Dreamer,,man i wasn't certain there was one but my eyes an nouse was tellin me there should be somthin there im so happy i aint goin mad, u should c the return i imrovised up it would give u a laff, ,,anyways its flithy cold up here on this mountain tonite the cricket from uk is on the telly so im so relieved about the spring thing i reckon i just go to bed keep warm watch cricket an wake up an fix my merc...thankyou,,,
Uncle tony
Ravenshoe 4888
W124 230e 1989
T
Righto,,cheers
Uncle tony
Ravenshoe 4888
W124 230e 1989
Okay ,,i did it, the first search i tested it with was,,,Tommy Woodcock &reckless, wow it works orright,,,i haven't seen that most amazing photo in years,,,
