adrianb
- May 24, 2004
- Location
- Nr Saffron Walden
- W210 E320cdi Est. W124 E220Est, W124 230TE, W123 230TE (various) W123 200T.
Hi all,
Apologes for clogging up the boards, but I've just rejoined the Mercedes family with a W124 230TE auto and it has a few foibles that need sorting out, and I've split them into a few threads in an effort to make it all a bit more manageable - this one is for the no heat problem.
Heating
I've got no heat. I can't grumble, it was like that when I got it. It's a non-air conditioned model. I'm almost certain that it's down to a clogged heater matrix, as the previous owner has had a s/h duovalve / pump fitted in an effort to fix the problem, which while you can feel it making an effort to pump, doesn't quite manage to produce any heat in the car. I tried switching the fan off for a while, disconnecting the Duovalve plug (to make it "fail-over" to hot) and then switching the fan back on, and did get some warm air for a bit, though it very soon went cold again. This makes me think the matrix is clogged up.
From what I've read, it's a bit of a b***er to change the heater matrix - but I'm prepared to give it a go. What I need to know is how to do it. I've had a 123TE, and had the dash off - and back on - that without too much grief for a simlilar job. But I'm clueless as to where to start with a 124, trim removal, what order to remove stuff, the fixings I'll need to deal with etc. It doesn't have any air bags, so at least I don't have to worry about that. I'm more than happy to take some pics and write some text to show progress and provide a guide to others, though the job will have to wait until the weather dries out a bit, and I want to be really genned up before I start.
For starters, is there just the one heater matrix? Or is there a separate one for driver and passenger sides?
cheers for any info.
Heating
