richip
After bringing my 124 E320 out of hibernation I found that the ABS light stayed on. I searched the forums on this excellent site and realised that it was probably the OVP relay.
I charged the battery and checked the 15amp fuse on the top of the relay but neither solved the problem. I then removed the OVP relay, opened the case and prepared for some soldering.
On inspection I noticed that the clear plastic inner shield had some burn marks next to the smaller coil. Parts of the coil itself appeared to have changed colour due to burning.
Is this just a general failure - the relay looks to be the original item (000 540 6745) or should I be looking for another problem before I replace it?
I'd very much appreciate some advice.
