- Mar 14, 2005
- Age
- 89
- Location
- Daventry
- 2002 SL500, 216 CL500, all fully loaded
turnipsock said:The spring issue is now bothering me.
I found a picture I took when I first got the car.
I changend the springs and it seemed to end up lower at the front, even though these were genuine MB parts ordered against the chassis number.
The new europarts spring makes it sit even lower at the front.
The old picture has the car sitting with the hight looking correct.
From a stability point and the spring rate, they should only ever be replaced in pairs, and I have always pointed this out on spring threads.
I have put out earlier the following.
For safety,springs should should always be replaced in axle sets. Replacing a single spring on a axle is potentially hazardous as it will set up an imbalance in the suspension and result in poor handling characteristics due to inequalities in the spring rates either side of the axle.
Malcolm
