tom7035
- Dec 22, 2004
These 'off centre' washers are part of the pivot bolt and are responsible for setting the camber angles. Need to be set with special gauge when you're done turnipsock.turnipsock said:I pretty sure I have the correct springs this time, the heaviest ones.
I haven't looked into the rubber bits yet.
I took the whole of the suspension off tonight. The wishbone mounts are slotted. The front mount was all the way in and the rear mount was all the way out. These can be set with the off centre washers. Does this sound right? or should I get it set up properly once I get it all back together?
Cheers, Tom.
