W124 idling problem
grober
Scotland
W204 C200cdi estate
Here's a link for a DIY diagnosis and replacement of a wiring loom with defective insulation. THE FIRST COUPLE OF PICTURES ILLUSTRATE WHAT TO LOOK FOR. You may have to carefully dissect a few sections of the black outer wiring sheath to check the insulation of the wires inside- you can always tape them up afterwards if things are OK. http://www.peachparts.com/Wikka/M104WireHarness
T
tim124
W124 E280 Estate/1995/2.8
  • #22
Progress report: MB dealer carried out diagnosis which indicated fault with wiring loom and the AMM but I was, um, reluctant to pay dealer's labour and parts charges: hence booked with local Indie. Car goes in for work on 30th November, will let you know how we get on!
T
tim124
  • #23
Update report: wiring loom and MAF replaced on 30 November, seems to have cured the problem - been driving it without any 'stalling' or 'hunting' whilst idling. Many thanks, if I may, to The Phirm for doing the work (and they specialise in VWs!!).
Nice to know that it is fixed,,very good news thanks for posting back
6
6pot
Nice to know its been sorted, ive got the loom to the coils to replace at somepoint in 2010!
salmanhamid
C220 CDI W203
Hi Tim
I have exactly the same problem, how much does it cost you to get the wiring loam replaced?
Salman
jibcl500
Cambridgeshire
CL500,ML55,SLK280
The 220 loom is easy to fix as its only a 4 cylinder, £400 roughly buys a new loom but a day with a soldering iron will fix it.
jib
www.ckinsurance.co.uk
