W170 SLK roof problem
coventryslk
Coventry
W204 CDI Sport
roof been down over weekend and no issues. I have had the c post casings off and cleaned them
DJC013
Horsham, West Sussex
2001 SLK 320 Auto in Linarite Blue / Black Leather
Hello again Malcolm, please could i have a copy of these instructions as well. Many thanks in advance, regards Damian. :)
I have sent them you can remove your address in edit
coventryslk
Coventry
W204 CDI Sport
no more roof problems..... think it was a one off and the weather was very cold?
busby20
Glasgow
SLK's 2, CLK320 Cabriolet.
Might help someone out, I had a problem today with an SLK roof. Customer found roof sticking at the front while trying to open, but a thump over the manual release cover above the rear view mirror would get it moving. Accessed the mechanism by removing three screws each side holding headliner side trims and three screws in the front shut area that hold the headliner. Both front latches were working correctly, but there is a cable attached to each latch that operates a further latch at the side, above the tiny rear 1/4 window. These cables have an adjuster each at the front section, and a small adjustment of each was all that was necessary to rectify the fault. If demand exists I could take some pictures...
Mine does this also, give it a thump at the driver's side catch and it opens, didn't know there were cables or adjustment for this:confused: Pics would be good ;)
I need the Email address so that I can send the details
All sent,,you can edit out your address
van883
Nottingham
1989 500SL 2003 CLK320
Think I might just have experienced this problem myself.
Operated the control, and the side and rear windows dropped as usual, started to raise the boot lid to accept the roof and then stopped abruptly with the lid raised about 15°.
After the sequence timed out, the close operation worked normally to lower the lid and raise the windows again.
I was suspecting a dodgy microswitch somewhere stopping the sequence, but I guess the roof failing to unlatch would have the same effect.
Does this sound like the fault you saw, or if not, any ideas where to check?
Operated the roof when I got home and it behaved impeccably, so so far it's an intermittent problem - but I doubt that it's going to go away on its own. :neutral:
hi
I would like these pictures please!
Van
tsargeant
Wiltshire
'98 SLK230 tucked away for the winter.
Dear "television"
I've just inherited a '98 230 with the same tricky little problem, would you mind sending me your remedy guide?
tom at permanden dot co dot uk
Thanks in advance!
Dear "television"
Thanks in advance!
I am a bit lost on this,,what is your fault please
tsargeant
Wiltshire
Hi Malcolm, first off thanks for the reply.
My roof requires a "thump" just behind the rear view mirror. From reading the other posts this on this thread it sounds like one of the latches or microswitches is sticking, or possibly the cable from the front latch to just above the 3/4 windows requires adjustment.
It sounds like you have some pics or a service guide that might save me some time, would you mind sending them my way? (I doubt I'll get around to looking at the roof until the spring now though!)
Rgds,
RadarUK
Kent
Me too
Hi Malcolm,
You certainly seem to be in demand...
Can I also have a copy please. My wife's car seems to have this exact problem.
my email is nvontunzelman@yahoo.com
Many thanks in advance.
Hi Malcolm,
Due to the complications on this thread,,what are your problems please
branstonpie
New Registration
SLK roof problem
Similar thing, however, roof completed operation but quarter light on passenger side would not raise, sounds like a grating sound - possibly wondering if cable snapped? Other than that, roof operation perfect. Could you please send me a copy of the sheet? claire.bradley1973@btinternet.com Many thanks!!
I have sent you details of the rear window etc,,you can edit out your address and welcome to the forum
Chris4431
New Registration
Hi can you help, have 230 slK roof not working at all, pull roof button/switch back and nothing happens, no noise at all, no window movement etc. If i push roof switch forward there is a noise from the motor for a few seconds. I have gone to release the front by pulling plug out by rear view mirror but the bolt seems to be fully stuck too. Any ideas. The shelf in the boot is in place. the fluid seems a little low in the boot though. chris.bunyan@btinternet.com
