w203 C180K Limp mode.
ilikepatrick
Bristol
C180k 2004 1.8 w203
Hi guys.
About a week ago the engine light came on my dash board. I drove home as I was not too far away and turned the engine off. I started it again about 5 mins later and the light was off and as far as I could tell everything was ok. The next morning I was driving to work and realised that the indicators were not working. Upon further inspection I realised that the rev counter and the speedometer were not moving (it was very early which is why it took a while to notice). I pulled over and turned the car off. It then took several turns of the key to turn it back on again but when it turned on it was running fine. I since have been told that this is emergency or limp mode. One of my colleagues had a diagnostics machine and when we plugged it in it said that there was a problem with the max air flow.
Since then I seem to be in limp mode every time I start the car after a long period of inactivity. I asked the garage if it just needed to be cleaned or if they had to replace it and they said they would have to charge me £215 to replace it.
Does it really have to be replaced or can it just be cleaned and if so can I do either myself.
Thanks in advance.
Steve@Avantgarde
Bristol/Somerset
Although the engine logged the MAF sensor, this may not be the issue. The engine ECU will limp the engine via the MAF by removing its signal wire, logging a fault code.
I would have it investigated by a MB specialist who has STAR.
I can recommend 2 good indies in Bristol or as I live in Bristol, you can drop it off at my house and I will take it to work with me and take a look for you. PM me if you need any help.
I
ilikepatrick
Bristol
C180k 2004 1.8 w203
Cheers Steve.
Well that doesn't sound as small a job as I first thought. Probably a stupid question as it is exploratory work but any idea on price?
