W204 How to increase the ride height?
Sebastian-w204c200
W204 C200 2008 Kompressor Sport
Hi Guys,
Got a C-Class 2008-W204-C200 Kompressor Sport model (AMG Appearance) on 17inch wheels. It’s ride height seems to be very low since I brought it. Not a being big fan of low ride height. Other C-Class in the same year seems to have high ride height when parked next to mine. Is there any way of increasing the ride height without damaging the car?
Thank you for your help in advance
Spring change is the normal way. You may also need new dampers.
Hello and welcome
Might be worth checking that it hasn’t been lowered by the previous owner.
Sebastian-w204c200
Sebastian-w204c200
Hello and welcome
Thanks, but the old owner has changed his number. The car is comparable low with C-Class. It is definitely lowered chassis.
JBell
Torquey
C350 CDi Estate (GAD Edition)
If it is a Sport it will ride 15mm lower than the Elegance as standard so putting a set of standard springs and dampers should raise it up
Sebastian-w204c200
Sebastian-w204c200
Thanks, it is a Sport so could I just buy ‘Elegance’ standard springs and dampers and fit it right?
Yes. You'll need to get it re-tracked as well as it will alter suspension geometry.
Finding the right spring combination could be difficult as there are more than a few combinations for some cars.
Gazwould
C250 CDI
Hi Guys,
What's the tyre sizes ?
Sebastian-w204c200
Sebastian-w204c200
Cool, Thanks
Gazwould
C250 CDI
It may be as simple as getting some 18" AMG 7 spokes , the diameters are bigger but my experience and others of plus sizing is the difference is bigger due to tyre manufacturers varying widths and profiles to the stated size depending what they want the tyre to do .
Plus sizing = plus rising .
JBell
Torquey
What would be the point??? going from a 225/45 R17 to a 225/40 R18 (the correct size on the front of a W204) will only increase the height by 0.1", hardly the 15mm you get by putting the non sport suspension on, you would have to go to a 225/45 R18 to get a 12mm rise (25mm diameter increase) but you are then throwing the gearing out as the circumference has gone up by 4% and the max recommended increase or decrease is 2.5%
Gazwould
C250 CDI
You can't apply maths when tyre widths and profiles are not accurate . They manipulate depending what they want the tyre to do .
What's the overall diameter difference between 205 55 16 and 235 45 17 ?
JBell
Torquey
You can't apply maths when tyre widths and profiles are not accurate. They manipulate depending what they want the tyre to do.
Yes you can, all based on standards in the industry, variations will occur depending on tyre shape and construction but they have to be manufactured to a small variance in order to comply with car manufacturers specs
+1.6%
www.ckinsurance.co.uk
