Operations
- Jan 7, 2021
- W204 - C350 - 2007
I own a W204 C350 build in 2007. Which means it holds the 30GB HDD.
Now i know i am asking a question which has been asked before. But i am finding quite a lot of conflicting information, even more when i include the topics on Dutch forums. Plus because the car is getting a bit old, a lot of the topics are old and are often mentioning dead URLs.
Please correct me if i am wrong:
I am able to replace the 30GB with an 40GB Ata disc. Mercedes normally uses a Toshiba MK4036GAC 2.5" Automotive HDD 40GB. The biggest concern is using one that can handle the vibrations better than a standard disc.
But on many dutch forums the say that it is not possible to simple clone the 30GB to a bigger one. The car will not accept the new disc because the disc is encrypted/encoded. Is this true?
I have found some topics that talk about making the music partition a bit smaller, if you do this it should be possible to install the newest available map dvd. Is this true ? But they do not say how to do this or the links are dead (i know how to use partition tools) and the warn about the encryption. Does somebody know how to do this? It would probably be the easiest way to go.
Simple last question, updating the map is that done by the Engineering menu and than the software update version?
Maybe a dumb question but is there also a way to update the Comand system? My car holds a NTG4, as you all probably know
Any ideas?
Any ideas?
