w210 e240 spark plug socket size?
dieselonly
york
w163 320, previously w210, e240 estate, w124 300, w123 300td w123 240td c220cdi w210 240 w210 300td
morning, I was planning to change the spark plugs in a 99 e240 v6 today but have no idea what size socket is needed? Im sure I have tried everyone in my box!
mikestrivens
Stockport
Most socket sets have a dedicated spark plug socket. This is generally longer than the others to clear the spark plug top and often has a rubber insert to protect the spark plug.
teddycatkin
cheshire cheese country
normally 14mm ?--but take care doing this as the plugs are so hard to get at its no easy job !
Do not forget to lever the caps off with a cranked open ended 17mm spanner over the top of the engine to avoid damage to the coil packs
Alex Crow
Super Suffolk
socket size is 16mm, or more accurately 5/8" :shock: as with wheel rim sizes, much of the world has stuck with imperial spark plug sizes, however 16mm is practically the same size and the two are interchangeable.
D
dieselonly
york
thanks chaps, I called mercedes this morning & they confirmed its 16mm although my 16mm wont get them out! maybe a need a thinner wall.
teddycatkin
I stand corrected !-I thought they were 14-trouble is you just cant see em?
