w210chap
- Jun 3, 2009
- e220 CDI 2002 Saloon Elegance
Hi, I've just replaced 4 of the rear suspension arms/struts on my W210 saloon - all of them on both sides except the main arm that the spring and shock attach to. Did this to try and fix a shaking that only occurs when I turn right especially going around roundabouts. The final arms I changed were the thin straight ones that the brake cable attaches to, that have the ball joint on the outer end. Only after changing them I now get a clunking noise when going over bumps, and sometimes when pulling away from stationary. I've had the tracking done at a garage with a hi-tech laser system that meaures all the geometries - still get the clunking.
Could it be that the ball joint nut is either too tight or too loose - I don't know what the torque setting is for this particular nut - I just tightened it as much as I dare (using an allen key in the end of the joint bolt to keep it from turning while I did up the nut). Does anyone know what the correct torque settings are for the rear arm nuts/bolts, or what else may be causing the clunking noise?
Any ideas greatly appreciated.
The car is an E220 CDI elegance.
Thanks in advance.
ps the new arms are all Lemforder, but appear identical in shape and size to the MB parts I took off.
Thanks in advance.
