W211 Boot leak - think I've sussed it...
broken_cross
W211/2008/2.2
Have had the water in boot after heavy rain for a while now - as I had the day off today so had a look. The rubber along the 'weather trim' on both sides was perished with cracks in it and coming away on one side.
there was a considerable amount of gunk under each side and moisture so suspect this is the source of the ingress.
i poured 20 litres over the rear and there was only one area I could see the water coming in...
I’ve got similar cracking on the plastic trim around the boot seals of my E class . I would be interested to know what it will cost to replace
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
I replaced those bits on my W211.
Under £40 for both sides including new plastic pins.
I have a thread here somewhere, but the search function isn't playing.
That’s sounds very positive , I was thinking hundreds
We’re they MB parts only ?
broken_cross
broken_cross
W211/2008/2.2
Not had any luck locating these myself - mostly US ebay :(
AMGeed
Poole, Dorset
Yes, I ordered them from the dealer and they arrived from Germany in around 5 days.
Part numbers looking at the EPC are (double check with the parts dept before ordering)
Nearside plastic cover A 210 693 01 33
Offside plastic cover A 210 693 02 33
Expansion rivets (count how many you need for each side if they aren't supplied with the above parts)
A 000 990 84 92
broken_cross
broken_cross
W211/2008/2.2
Good shout - I thought it would be more expensive via dealer but filled out online form, quick call back and they will have both sides and new plugs £40 on Tuesday. thank you
That is very good buddy , which dealer is that just in case my local one does have the same pricing .
broken_cross
broken_cross
W211/2008/2.2
Well, the boot is still leaking with the new parts fitted. :(
Can only surmise that either the after market towbar is poorly fitted or the water is leaking under the weather trim still - there is enough of a gap where the rubbers meet from window gutter.
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
When I cured mine I took the plastic number plate panel off and renewed the poppers with the felt pads on , there's quite a few . Used black silicone on all the holes before refitting. Siliconed around the 3rd brake light and also ran a bead the length of the said panel at the top. I never saw water again.
