W211 OM642 Smoking and losing oil
Stian OM642
W211 OM642, S124 OM606, S210 OM613
Hey. I got a W211 OM642 engine. I changed turbo once because it was dragging oil into exhaust, brand new turbo. After change i have to fill oil every 5-6 days. I have changed the crank ventilation, and this cover behind, and still no changes. It Smokes much. Looks like i create a fog behind me when i drive and covers cars behind, white/grey smoke. EGR is removed, and DPF and cats are also removed. And i cannot find the problem. Can it be internal in the engine? Or can turbo be bad already? Changed it 1 month ago..
hmang
Careful if you are getting excess fuel in the cylinders .
if it's not all burning ,it could get past your piston rings and dilute your oil
ajlsl600
france
Doubt that op saying he always topping up oil level. If no turbo issues .guides,rings .start with compression test . Then hold rpm at smoking point,inplug/ back off injectirs 1 by 1 see if that locates issue.
Doug1234
Bedfordshire uk
1997 w210 e300td
Injectors and ecu can be damaged by unplugging when engine is running.
ajlsl600
france
Moat decent diagnostic kit allows for dropping injection off 1by1
If its common rail a work around could be a blanking plug on one outlet at a time ,no ?
star
Reading
Smart + others :)
Don’t dismiss a new turbo being faulty, remove exit pipe to check.
Stian OM642
I took of pipe behind turbo, and the propeller was clean but much oil in pipe, almost like glue texture. I am guessing piston rings, im doing comp test as soon as i can
star
Reading
Smart + others :)
Did you check exhaust manifold pipes to see if clear of oil? If rings, there would be a lot of crankcase pressure.
Stian OM642
I would not say that its much pressure in the crank case, not that i know of. But no there was no oil in the manifolds as i could see, only exhaust behind turbo
star
Reading
Smart + others :)
Then I would suspect turbo.
