W211 wagon rear shocks
pgh13
Nr Leamington Spa
E320CDI 2004 - straight 6 diesel
I have a 2004 car with 177k which exhibits what Kent of Mercedessource describes as 'Dead body in the trunk syndrome,' as well as occasionally hearing a wheel bounce a couple of times on lumpy bits of road.
Thinking rear shocks would be a good idea but the car doesn't justify spending a fortune. I can see lots of different dampers at widely varying prices. the ones on the car have an external module attached to the lower end - something to do with the self levelling?
ECP show a Bilstein which looks like it, with the module, but at £815 each is more than the car is worth.
Any thoughts?
P
pgh13
Nr Leamington Spa
  • #2
Can anyone tell me the OEM part number for the rear shocks?
VIN is WDB2112262A494898
P
pgh13
Nr Leamington Spa
There's a good price on these but they have 2 similar variants both listed for E320 eastate but with a different OEM part numbers
P
pgh13
Nr Leamington Spa
Well, I ordered what I thought from Autodoc but now they've arrived, they don't look right. The ones on the car have a cable connection but the ones received don't.
From the VIN listed above, does my car have sports suspension?
Doesn't look like it:
  • WDB2112262A494898.pdf
P
pgh13
Nr Leamington Spa
The shocks on the car have an additional small cylinder attached by the lower mounting point. I had assumed this has an electrical connection, but on closer inspection I can't see any wiring. Are these reservoir shocks?
I've seen articles saying they are superior, but is that overkill for a 16 year old car?
P
pgh13
Nr Leamington Spa
This is the type of damper fitted currently
That does look like a piggyback reservoir. They have the benefit of more consistent damping performance.
P
pgh13
Nr Leamington Spa
The other Bilstein unit listed on Autodoc is
https://www.autodoc.co.uk/bilstein/638159
This looks like the part that I have, including the bellows around the spindle and the reservoir. The only reason that I didn't order that is that it states it's for cars with sport suspension. There was no picture for the unit that I did order, otherwise I would have realised the problem
