W213 220d engine management light on
Petergordon
E220 estate 2017
My garage checked and said NOX SENSOR failure but main dealer needs to do ,booked car in with main dealer but 2 days later engine management light gone out ; 220d does this car have a regenerative system so it cleans out ,should I still go to main dealer Tuesday as booked ,car running fine
Dean Fletcher
Penrith, Cumbria
Mercedes E400
Its will have a DPF, the engine lights is programmed to go out after so many ignition cycles. Think it could be 20 or 30? Not 100% sure. The car won't regen if in limp mode which will cost a fortune if blocked. Best to get sorted really.
Srdl
Hampshire
GLC43 AMG 2018 (X253)
We are seeing a lot of problems with NOx sensors on here and you should find that Mercedes will make a decent contribution to the cost even though your car is out of warranty. Have you had a emissions related software update recently? A lot of NOx sensor faults seem to follow this update.
P
Petergordon
E220 estate 2017
Thankyou
P
Petergordon
E220 estate 2017
Thankyou
ssheikh93
London
W213 E220d
Where are you based?
P
Petergordon
E220 estate 2017
Cambridge why
Djhypersp
E220 coupe
I had my engine light come on with a nox sensor fault, went off after a few restarts then came back on again. Took it to merc Cambridge and they replaced both sensors foc out of warranty
P
Petergordon
E220 estate 2017
Thankyou that’s where I am going Tuesday
P
Petergordon
E220 estate 2017
Would you mind me asking how much they charged you ,as I am booked in Tuesday MERC ,Barnwell road ,Cambridge
Srdl
Hampshire
foc = Free of Charge
They’ll most likely charge a £100+ diagnostic fee which if the work is covered under warranty you’ll get back.
onefortheroad
uk.
Do you talk to yourself at home ?
