Botus
How on earth do cars pass an mot with Van Helsing's coach candles and oxidised plastic headlight lenses ?
coz an MOT is more about the brakes work and nothings going to fall off, than safe motoring
That should be enough reason not to fit them.Aside from them being illegal and too bright Do the hid kits throw up an error when installed then ?? Ta
Thanks for replyingthere is no point...
if u wan to go illegal run LEDs, the good ones are much closer to a std bulb, so give other road users less issues
if you want legal you can waste £35 and get a pair 1/2% more glow wormness by fitting a set of night breaker plus H7s, get 4 or 5 sets you'll have used them before the end of the year
most throw errors, u fit a set of resistors that wastes the amount you saved by running a more efficient bulb and the car knows no better, some cars cope with can bus error free bulbs… others don't. I have no idea how fussy merc are (but I can believe they are one of the least tolerant).
I put a set of T10s Error free LED sidelight bulbs in my bike, when the battery was good they were ok. If I started when the battery was a bit low it threw the error, run for 1 min stop and restart they were OK again
But they are legal.they are mistaken
That’s good to knowBut they are legal.
Daytime Running Lamps are NOT headlamps. They are limited to 600 lumen by regulation and have a completely different beam pattern requirement to headlamps. Nonetheless if your car had some form of conventional lighting source for its DRLs and you replaced those with LED- they would still be illegal.Thanks for replying
So your saying the osram nightbreakers do not last as long as normal bulbs too ? That correct ?
Just liked in my book and drl lights are also headlights too so don’t think I’ll bother lol was looking to swap h15 drl bulbs to led too but as there headlights too I probably won’t bother
Thanks.
Basically if the light unit is e-marked (and it will be) then the light source must have a corresponding E-mark.I would presume through type approval bowlacks that even halogen - led reversing lights are illegal ?
Just fit some of Nordic lights in wide flood they make excellent rear work lightsMy valid reason is halogen P21W are rubbish and 80W-100W equivalent Cree led are superb especially when there's only one silly reversing light .
So when you're in town at night reversing to prepare to leave a parking spot where someone is parked in front of you, how much do you think you're inconveniencing cars coming up behind you with your super bright non directional reverse light?My valid reason is halogen P21W are rubbish and 80W-100W equivalent Cree led are superb especially when there's only one silly reversing light .
Clearly someone else who doesn't care about other road users then.Strange you say that a guy with a W203 behind got out and tapped on the window asking what and where from as impressed , lol .
