Who hasn't used a screwdriver back in the day... (and then found out the replacement you'd bought didn't fit...)ar, that's what it is, an oil filter, has someone not used the correct tool to remove ?
The main problem is : No body read the installation guide on a filter . If someone over tightening , then you have a no choice and you must breaking the Isaac Newton Laws and use your Own methods to remove it.ar, that's what it is, an oil filter, has someone not used the correct tool to remove ?
Where is it people put their fingers when changing pads so they could be trapped by a sudden brake application by the SBC.... I've often wondered. In between the disc and piston? Why would you do that?i fitted a set of pads in an 07 CLS500 for a mate a few weeks ago , didn't touch the SBC , just swapped them out , happy days
I think You both missed somethink. The guy told Us:::::------ He disconnected it because he change an air spring as well.Where is it people put their fingers when changing pads so they could be trapped by a sudden brake application by the SBC.... I've often wondered. In between the disc and piston? Why would you do that?
It's you that didn't read it properly and missed something. He previously worked on his suspension and thought the brakes would be no problem after thatI think You both missed somethink. The guy told Us:::::------ He disconnected it because he change an air spring as well.
Did you get that??? Or just to make your score up???
