Wanabe mechanic may have killed his car!
Gazwould
C250 CDI
By a very special person , the things he does on a regular basis is like nothing I've experienced before .
joderest
ML270 2003
ar, that's what it is, an oil filter, has someone not used the correct tool to remove ?
Who hasn't used a screwdriver back in the day...;) (and then found out the replacement you'd bought didn't fit...) :( :mad:
Ivan Mihov
Royston
S203 C200 116bhp/W211 E220 147bhp
The main problem is : No body read the installation guide on a filter . If someone over tightening , then you have a no choice and you must breaking the Isaac Newton Laws and use your Own methods to remove it.
I call this A magic :)
joderest
ML270 2003
I call it an "oil filter strap wrench"
bembo449
gainsborough , lincolnshire
i fitted a set of pads in an 07 CLS500 for a mate a few weeks ago , didn't touch the SBC , just swapped them out , happy days
noonboots
R230 SL 500 2003 M113 5.0l
Where is it people put their fingers when changing pads so they could be trapped by a sudden brake application by the SBC.... I've often wondered. In between the disc and piston? Why would you do that?
Ivan Mihov
Royston
I think You both missed somethink. The guy told Us:::::------ He disconnected it because he change an air spring as well.
Did you get that??? Or just to make your score up???
noonboots
It's you that didn't read it properly and missed something. He previously worked on his suspension and thought the brakes would be no problem after that
www.ckinsurance.co.uk
