Wanabe mechanic may have killed his car!
Purplebarron
55 plate CLS 500
Hi, all
I recently changed the front brake pads on my 55 plate CLS 500, I watched a video on YouTube and thought easier than when I replaced the front airmatic suspension, so got to it.
I disconnected the SBC, so wouldn't suddenly engage and trap my fingers.
It went well brake pads came out and went back in fine.
I started her up to take for a test drive and, ohhh!!! the Abs and Esp warning came on and the steering was stiff.
Is it just a case that it needs to be reset again ?
Ps I don't want to be a mechanic anymore!!
Wearsafoxhat
Sunny Hampshire by the sea
E55k :S211, SL500 :R129 , V220
Have you plugged the SBC back in correctly ?
You could then try turning the steering wheel lock to lock a few times. After that I’m leaving answers to the experts.
Is there a wheel sensor cable that goes into the back of the hub , maybe this has been displaced ?
onefortheroad
uk.
Did you drive the car after the change ?
mioba
Nottingham and Köln
Bit drastic to say you have killed the car.
Get the codes read, clear the codes. If it comes back then you have identified the culprit.
P
Purplebarron
55 plate CLS 500
Hi, I had it rigged up to a fault diagnosis and managed to clear all codes but as soon as I unplugged and started engine It was back to square one. I have a mobile mechanic taking a look next week with a Star diagnostic so hoping he can sort ☹️
Janchee
Ex W213/2016/220D 190
Hi, all
My guess is with the other guys - wheel sensor. Did you take the brake reservoir cap off when you did it? How hard were the pads to spread and get out?
onefortheroad
uk.
It could just be crap on the sensor face . ?
P
Purplebarron
55 plate CLS 500
Hi, no I didn't and they were pretty tough to spread and remove.
Thanks for reply
star
Reading
Smart + others :)
Sometime the sbc trips s fault after a pad change when pushing the pistons out.
Janchee
Thanks for reply
I normally extract some from the reservoir before changing them if it’s quite high but always take off the lid. It could be why it was quite hard to push them back as it is a sealed system. I don’t know if you could do damage to the system if this isn’t done. No expert lol
star
Reading
Smart + others :)
Not sealed as such, small pin hole breather to allow fluid to drop.
Janchee
Is it like an NRV though? Could you do some damage by forcing brakes back in when sealed shut?
Gazwould
C250 CDI
At times I feel like Han Solo as I've seen alot of strange stuff...
Ivan Mihov
Royston
S203 C200 116bhp/W211 E220 147bhp
Do you have any other faults on ?
I mean battery light .
