1976 450 SE Handbrake Stuck On -- HELP
Devonchick
We have inherited a Mercedes 450 SE Auto after our uncle died. We are trying to sell the car to pay for the funeral expenses.
After leaving it parked outside with the handbrake on the drivers side handbrake is now locked on. Despite plenty of penetrating oil, rubber mallet and rocking backwards and forwards it refuses to unstick.
Does anyone have any suggestions. We have looked at removing the disk but this seems to be impossible. Short of trying to dismantle the entire handbrake we can't think of anything else.
Any help would be appreciated.
dieselman
A diesel
Have you tried just driving it....Needs more revs... ;)
Seriously, the shoes have stuck to the inside of the drum.
Is the handle releasing and going back but the wheel is sill locked
Alex Crow
Super Suffolk
have you been able to back off the adjuster inside the hub? it is a small toothed part that can be turned with a screwdriver. failing that they may well be corroded to the inside of the disk as dieselman suggests. the idea of using engine power to free them off does have some merit...
If using the engine R is better than D owing to the design of the parking brake shoes
D
Devonchick
Thanks for the replies.
Yes the handbrake is fully released and the the wheel is still locked on. Underneath the car the cables seem loose but not sure they are moving properly.
Interested in the adjuster screw, can't see anything on the wheel?
If you cannot turn the wheel,,then you will not be able to line up the hole in the hub to get to the adjuster,,do try putting the car into R and see if it comes of, it will be near impossible to get the drum part off as it stands due to the lip that will be inside the drum
D
Devonchick
We can turn the wheel with the car jacked up , is the whole the one where the wheel nuts go through ? We need pictures or drawings as we don't really have a clue . Basic knowledge , but have a go mentality .
Thanks for the help so far , really is appreciated .
Here is a photo of the wheel hub with the drum part off,,right at the top just to the left you can see the toothed ratchet wheel, you need to line up one of the holes in the drum so the you can get a flat bladed screwdriver in and flip the wheel round, to back the shoes off
D
Devonchick
Great thanks for the picture , will try in the morning and let you know how we get on . Fingers crossed .
Alex Crow
Super Suffolk
if you are still struggling devonchick, i am sure malcolm would love to pop over to lend a hand. he is a really nice guy and is always happy to help.
I have my own problems
D
Devonchick
Thanks guys, but if i am to work on the car in the morning i really need to get some sleep . Will update as soon as i have any news or problems .
Pontoneer
Banned
Here's what is shown in the owners' handbook ( do you have it in the glovebox ? ) This is from a W114 manual , but the W116 is similar .
Bear in mind the adjuster will be at '11 o'clock' on one side of the car , and 'one o'clock' on the other !
Same info , but a bit more detail , from Autobooks workshop manual
It would be worth posting a few pictures of the car on here - a member may well be interested in it . W116's are becoming quite rare now and of the few that have not rusted into oblivion those that remain tend to be either well cared for examples that are now collectors' items or else basket cases only good for spares . It is , sadly , the often forgotten and overlooked S Class . When the 'official' club had an S Class day , last year , the W116 was the only model not to be represented , due to the low numbers still around !
roofless
w124 e220 estate
One easy thing to try is get a good hold of the cable behind the wheel & give it a good wiggle up & down as it could be the cable sticking
Pontoneer
Banned
If the adjuster , and reversing ( not driving forwards ) do not free it off , I'd get a decent sized club hammer and set about the drum , not being shy about it .( wearing suitable eye protection ) . Application of heat to the drum may also help .
Pontoneer
Banned
We can turn the wheel with the car jacked up .
Just spotted this comment - why do you think the handbrake is seized on if you can turn the wheel by hand ? Do you hear 'rubbing' ? Or is there some drag ?
As per my above comment - remove pads and caliper from disc brake , one small screw holding disc/drum assembly to hub and it should knock off with a hammer/application of heat . Probably stuck to hub with corossion .
As the car is being sold, and in view of Ponteneers post above,, I an in Exeter next week as I have to return some parts,, I am quite happy to pop in and look the car over as a guide to anyone who may be interested in buying it.
D
Devonchick
  • #20
Success!
Thanks to everyone on this thread your ideas and comments have been really useful - especially the diagrams. In the end I found the adjuster as alexander_patient suggested and managed to back-off the pads. Even better the handbrake still works and now releases properly, which is great.
Malcom (television), would be happy for you to come across and give us your expert opinion on the car. We have put it up for sale as the Executors have instructed us. Follow this link to take a look at more information and pictures. We need to get as much as possible to pay for the funeral etc.
Any advice, words of wisdom, or general thoughts would be appreciated.
Cheers
