1978 207d engine swap to om617.951
Corby
petaluma, Ca
1978 207D
Hey Guys, I'm new to the forum... primarily for help on a project I have coming up. :)
I work for a company that owns a 207d as a marketing rig, and the stock motor just blew... in the desert... 450mi. away.
So, rumor has it that we can put a OM617 in there with minimal work from a 80-85 300sd or 300td which is a much more reliable engine.
Does anyone have any experience with this particular swap? I'm trying to gather as much information as possible so that we minimize all the extra expense and most mistakes along the way.
Any input would be appreciated, Thanks!
robparker
Taunton
What's in it now, a OM615?
C
Corby
petaluma, Ca
1978 207D
I'm pretty sure...
It's a stock 616.
C
Corby
petaluma, Ca
1978 207D
I believe it's the original 616.
robparker
Taunton
I can't imagine it will be hard, it's the same engine +1 cylinder. No more or less reliable. But i don't suspect anyone on here will have had that vehicle and done that swap! So info from experience will probably be limited, if in existence at all!
C
Corby
petaluma, Ca
1978 207D
Ha! Okay, well point taken. I appreciate your input!
om613
london
S202 C250TD, S123 240TD
The 616 and 617 are of equal, high reliability.
Putting a 617 in a 207 van - is there adequate clearance for the extra cly?
300SEL63
I worked at a place some time ago where we did this swap ,the trans had to be moved back 150 mm and.... it went as fast as the four cyl going down hill. :D engine. A better choice would be a OM 606 turbo .
frank1989
207d
How did this conversion go?
Has anyone tried to put a 4 cylinder petrol engine in - from a 190 e or similar
