(1997,E230,m111.970 )Engine shuts off when pressing gas pedal from idle state
amkahal
Lebanon
E230 Avantgarde 1997
Hi all,
I have a problem on my car, all is normal until i put D and when pressing gas pedal the engine shuts off, noting that not always happening, it's random.
at many times, when pressing gas pedal, the RPM goes down for a while and then to normal and the engine dosent shuts off.
another observation, when parking, and when turning steering wheel to max limit and pressing gas, the engine also shuts off.
(during driving the car is perfect, the problem only occurs when pressing gas from idle)
Where to start ??
You could try unplugging the MAF, this effects idle when it start to fail, some cars will run better to prove the point but not all.
Peter G
Warwickshire
2013 SL 350, 1989 Toyota Hilux, 1987 Fiesta XR2
Recently had a similar problem with my 540i. Didn't cut out but hesitated when throttle applied.
A new MAF solved it.
A
amkahal
Lebanon
LAUNCH system shows "Camshaft position sensor L5/1 signal implausible/missing 067", does this problem cause such behaviors ?
mattkh
England
A160 W168 1999 1.6
Hi
It can do.
Check the electrical connection to the Camshaft position sensor first.
MEESEZ
I have same issue , Please write the solution her if you got it.
MEESEZ
Today morning I check cam sensor wire connection, there was resisters from cam wire connection, even the Engine control module was removed.
now the camshaft sensor is disconnected and there is not Different.
