JoeHorner
- Aug 21, 2022
- 2003 W203 C270CDI Elegance
I read on here lots of talk of "limp mode" but no fault code. It is quite possible you have some failure that is causing a torque limitation without a fault, I would not call that "limp mode".
Agree with rf065, it's often more than a simple torque limit.
On mine with a bad Baro sensor, it decided the MAP reading couldn't be trusted (as you suggest) and set an appropriate (it thought) fault code for MAP plausibility which doesn't show on standard scanners. But the response was to:
* disable the turbo entirely
* change into the highest gear possible as soon as possible (IE: 4th by about 25mph, 5th by 30 or so!)
* disable kickdown entirely
* limit revs to 2000rpm
That's considerably more than a simple torque limit and driving something this weight in a high gear with, effectively, a normally aspirated low-speed diesel c.1960s style fits a description of "limp" pretty well!
Also agree completely that xentry is the way to go. Hugely more versatile than any aftermarket kit, even "brand specific" stuff.
