Air filter housing seal
nodger
The top cover of the air filter housing in my W208 doesn't seem to make a clean seal with the box itself. How important is it for a complete seal to be made? I understand that you don't want dust and dirt being sucked in, I'm just wondering if it's supposed to be air-tight for performance reasons?
I was thinking of laying a thick line of silicone sealant around the top of the box and allowing it to dry before attaching the lid. Would this be OK?
Thanks in advance.
Is it a genuine or correct filter do you know,,, they are normally a very good fit
N
nodger
Hi Malcolm,
Yes, I think the filter itself is a perfect fit. The top cover just seems to be very slightly warped, possibly due to being incorrectly fitted over a long period of time. I just took a look at it and all of the clips are secured correctly, but the rim between the box and the cover doesn't seem uniform all the way around. I suppose I'll ask the dealer how much a new box would cost, just to be on the safe side.
Thanks.
If the filter fits well does it really matter then about the top lid
Roxie
Lincolnshire
C Class 350CDI 2012
This will only be of use if you never want to take the lid off ever again.
N
nodger
I suppose my concern was that if air (whatever about dust/dirt) is leaking into the box after the filter, that it might affect some measurement of airflow/pressure that might be taken by the system. I'm a complete novice though, it was just a thought :)
N
nodger
Well I was planning to let the silicone dry before reattaching the lid. Would the heat of the engine bay 'melt' it again?
