Jack1255
CLS500 / 2005
Hey all,
C219 with airmatic, front left strut just changed due to split and caused red car too low message. Strut changed over but now after a min or two white message saying airmatic visit workshop.
Have scanned and cleared all airmatic faults but code 5507 - “suspension strut is unreasonable”
have unplugged and reconnected both connections to the strut, height sensor works as pump kicks in when raised / lowered by jack.
Does 5507 mean the strut is defective?
Have got a new compressor but is that code related to the pump or not?
Thanks in advance for any ideas :)
Jack1255
CLS500 / 2005
Just to add further info
I took the relay out and tapped it a few times, still same issue - have ordered a new one though just to rule it out.
Had another scan and I get the following info
How does it all look?
Voltages - 244, terminal 30 14V
091 - terminal 87 - ON
level sensors
Left 040 B22/8 - 2.49V
Left 041 B22/8 - 2.49V
front right is 2.63V
Rear is 2.53V
vehicle level
042 left = -9mm
045 right = 5mm
048 rear = 4mm
acceleration sensors
030 B24/3 (left) 2509.80mV
031 B24/4 (right) 2490.20mV
AIRmatic pressure
049 B7 = 17.16 bar
Is the left sensor in the tolerance range at 2.49V?
Am going to get the front up again so I can check the wiring connectors.
isohail72
Manchester
Mercedes S320 CDI 2006
Hi MAte, Did you managed to fix the issue?
Jack1255
CLS500 / 2005
Sorry for the late reply!
I ended up buying a Star system and after doing the guided tests discovered the strut was at fault, it couldn’t lower when requested so had to change the strut and issue went away.
Tel: 020 8863 9233
