Blank Radio Display CLK 320
avenger1234
I have a 200 CLK 320,, the battery went flat while in storage. But after new battery,, the audio display is blank and the information panel on driver display shows only _ _ _ _ Audio... I have checked the fuse in the engine bay and found it ok.. lost for any further ideas?
Anyone got a suggestion??
Thanks Avenger
Yes it is waiting for the code,,,if you do not have it ask MB and they will give it to you
A
avenger1234
Thanks,, the main unit is blank and has no display,, i have the 5 digit code,, but no response and the driver display just remains _ _ _ _ audio.. wish it was awaiting the code!!
I would remove the battery or the radio fuse for 10 mins and then power up again
A
avenger1234
Did the fuse,, but still nothing on the unit display,, no lights,, guess its dead... is there another fuse behind the radio unit. Anyone know where you can get the two tools to release the radio from the console?
The tools only cost £1.06 from MB or an ECE shop.
Even with the fuse out the memory is still live, so pulling the multi plug on the rear would give a correct full power down
A
avenger1234
Thanks for all help... upon removal of radio,, found a fuse blowing in the back of the unit next to all the input / output wires... replaced and now we have noise..
Thanks for posting back :D:D
