BRAKE EBD, ABS and ESC INOPERATIVE
Aldo ko92
2011 Mercedes c300 and 2014 Mercedes Ml350
Hello I have a 2011 Mercedes C300 4matic and today when I started the car and drove for like 2 mins the ABS SRS LIGHT CAME ON on the dashboard
It gives me the message BRAKE EBD, ABS and ESC INOPERATIVE
Any idea on what’s going on?
Hello and welcome
What condition is your battery in?
bertb1
C220 amp sport 2013
Hello
Could be a wheel sensor
Best to get the codes read from a Mercedes Indy
A
Aldo ko92
The same thing happened about 1-2 years ago after I changed the battery. Brought the car to Mercedes and they said that the ABS module needs to be replaced, I read on the forums in that time that the issue might have been replacing the battery so I had them to clear the codes and since then never had any issues Until now
A
Aldo ko92
Hello and welcome
Hello the battery is in good condition, the car starts right away, I will test the battery thou, but if it is good, what would it be?
brandwooddixon
Wolverhampton
S63 Coupe 2014
If it only does it when the car has sat for a while, but not if its run and then restarted, its possibly the battery.
Otherwise you'd best get the codes read, it may be a sensor, but which one?
A
Aldo ko92
Hello
The car has not been sitting at all
The battery is in good condition so I’ll check the abs sensors and hopefully that’s what’s going on
steveq
Dublin
2011 Merc S212 E220CDI Estate; Tesla Model 3; 1965 W113 Merc 230SL Pagoda
I had the same fault on my 2011 C220 about a month ago.
On mine it was a faulty front wheel speed sensor.
You will need an OBD reader that can see the speed of each wheel. I found that my icarsoft i980 would not read the values. It worked fine on my E220 and would show the wheel speeds correctly. With a bit of research I found that there is a problem on the i980 reading wheel speeds on the facelift W204 C Class from 2011 to 2014.
I bought the latest icarsoft MB V2 and that could read the wheel speeds correctly.
That identified that the nearside front wheel just read zero speed while all the other wheels showed identical speeds.
I bought an MB sensor, fitted it and the problem was resolved.
A
Aldo ko92
I definitely will try that. Thank you
Bay Leaf
Stockport
SL 350 R231 2013
How do you go about seeing the speed of each wheel with the scanner. mines a icarsoft MB V1.0
