Brake wear sensors
Adam__
a180 sport/2014/1.6L
Evaning all, i am about to replace my pads, disks and wear sensors but have ran into a problem. On some of the popular car part sites i can't seem to find rear brake pad wear sensors.
Is this becans the sensor is universal and fits into front and rear or can anyone give me a heads up were to look. Iv been able to find Brembo fronts but no rear.
Also correct me if im wrong but you only need 2 sensors for the 2014 aclass just 1 front and 1 rear?
Cheers in advance people!
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
I am not an expert but one wear sensor on each wheel, but I have never had a wear sensor light up ever. So if you check your pads regularly I don't see it as an issue. I change my wheels twice a year winter summer winter, & always have a good look at the pads & discs wear then.
I've not had need to look on my ML, but the wear sensors on my previous Merc were only on one wheel at the front & one wheel at the back ... and both sensors were the same
onefortheroad
uk.
if your careful , you can pull out the old ones and reuse them .
A
Adam__
Perfect cheers
