C Class W205 Brake Disc
JakeBlanchard
New Registration
C Class / 2016 / C220D
I have a w205 c class with the AMG pack. I’m looking for brake discs but can’t find the correct ones. Anyone have any advice on how to get the exact same ones (or as close too). I’ve phoned a few garages but they can’t seem to pinpoint the exact ones.
Thanks in advance m
R171 SLK280, Smart R451, 997 C2S, VW ID.5, R1250 GSA TE 40th, CBR600FP
Hello and welcome,
Phone Mercedes Grangemouth - they do forum discount and will supply the right ones
BMW 520i G30 2018 and E350d C207 Coupe 2017
Measuring your current ones should work , there are also details stamped on the hub that should be visible through the wheel gaps
EmilysDad
Bury Lancs
ML350
Having learned the hard way in the past, I use OE discs - what ever flavour car I have. While there are those that have had success with after market Brembo/Pagid/etc discs, I find that it's easier & cheaper in the longer run to just buy OE and as Blobcat says, you know you'll get the correct parts and they won't 'warp' after a handful of miles.
richlumb
GLC 350d
Hi there word of advice with C class brake disks , if there fitted incorrectly they WILL warp so spend the extra few pounds and get them fitted at a dealers then that way you will have some form of warranty, it’s a common issue with the 205 brake disks they are 2 piece disks (pressed hub)
Also, don't drop them or they're scrap :(
www.ckinsurance.co.uk
