C180: engine turns but does not start please help
Its in the control box under the bonnet
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Under the bonnet passenger side, just in front of the windscreen is where my ECU lives, though I believe some early C classes have a control unit fitted under the washer bottle.
B
benlauren
  • #43
Many thanks to Malcolm and Andy. Right so back to the question of do I need to do anything else apart from simply replacing it? and can I do that myself or do I need a guy with a special tool?
Just read back and the car is a 1996 so it is just plug and play
C
Carl Hills
Hello
My petrol vito has the same engine. I left it standing for three months then it would not start. I took the injectors out, checked the fuel, plugs etc. Nothing wrong. I bought a diagnostic socket tested it and it ws the crank sensor, I think the end gets rusty and won't read. I bought a new one (£85) and it worked fine. You may get away with cleaning the rust off the end but it is very tight and hard to remove without damaging the cable. I would bet it is the crank sensor. If your crank sensor doesn't know where top dead centre is, it won't spark and inject at the right point.
Good luck Carl
B
benlauren
  • #47
Hello
Good luck Carl
but the garage says they have tested it and it is fine!! Could it be they are not telling me the truth? They showed me a new crank sensor in the box! I have to take their words for it. I found a box (# 140 as Malcolm said) under the washer bottle and have taken it out. The car is about a mile away and i have already made three trips there and back. If the crank sensor is the root cause of the problem I shall slit my wrist.
A simple ohm meter will tell you, 1 k ohm when good
B
benlauren
  • #49
Thanks mate I have to make another trip to the car with some spanners. Seems a must do before i embark on anything else. Will let you know.
B
benlauren
  • #50
I manged to get a reading from the CPS and it reads 0.825 ohms.
That cannot be right unless it has gone short circuit
82.25K could be OK but not 0.825 ohms
B
benlauren
  • #52
I put the multimetre on 2k max and that's what i got. Sry that means 0.825 kohms
I am not awake yet and that looks to be OK, and near enough 1KΩ , they are funny things to measure as the field set up from the battery in the meter apposes the reading
B
benlauren
  • #54
so the cps is ok then? the garage said they put a new one in but still no joy.
Its OK and they were telling the truth,,sorry about the keeping fit bit, but I hate anyone buying things that they do not need
Oh thats it then. can't afford that. It is a shame because it has been a lovely car. Still taxed and the tank is full.
There are loads of these being broken up, you should get one cheap
www.ckinsurance.co.uk
