C220cdi 2011 oil leak
AddsG
C220/2011/2.2
Hi I have a c220 cdi coupe 2011 which has developed an oil leak. At first was just a tiny drip but this week the drip is now a mini puddle. The leak is presenting itself passenger wheel area. I was hoping to maybe diy but wondered if there was a common issue with leaks and what it could possibly be. At first it had water marks around the oil stain ( presuming rain water?) But now seems thick oil.
Any help appreciated.
Vehicle not smoking, no performance issues, no warnings lights, runs perfect.
ajlsl600
france
Oil clean ?check p steering and. Trans cooler and pipes.. oil dirty look where is oil cooler and pipes.by the way I dont know if cooler is with oil filter on yr eng or separate unit at front of car with pipes to one side ?
CowleyStJames
Oxford
Mercedes-Benz E63s, Old knackered G wagon
Similar with mine, OM651 engine, 2011 car. Turned out to be the oil cooler. It's situated beneath the oil filter, had to replace the oil filter housing and cooler(it's one assembly).
A
AddsG
C220/2011/2.2
Did yours puddle by passenger wheel too?
Steve@Avantgarde
Bristol/Somerset
C43 AMG PP/NE, SLR McLaren Roadster, SL55 & C32AMG
On some 651s, there is a valve that sits behind the oil filter housing, think its named as the piston shift valve on WIS, its designed to pump extra oil to the front of the engine, they have been known to leak too.
CowleyStJames
Oxford
Couldn't really tell as it pooled in the undertray until I moved off.
When the garage removed the undertray it was mostly directly under the oil filter housing. Have you got an undertray on yours?
A
AddsG
C220/2011/2.2
Thanks for the advice it turned out to be the Oil cooler and needed replacing.
Bunks
New Registration
C220 amg
I think I have this problem. How much did it cost to have it repaired please?
