Cheap winter tyres/winter alloys&tyres
Cgd
Cgd
C220/16/2.1
  • #41
Correct- the labour content is about 2/2.5 hours for 4 x corners so it’s c£135/hour vs c£70/hour and the pads themselves are similarly priced really. Is there less than 3mm on the pads then?
Thanks John
I would say fronts around 3-5mm and tears around 4-6mm
I got the dash light reminding me (which is quite amazing since the A1 service is also on...)
I had considered an Indie and sourcing pads online to get original parts
Rotorhead500
Very South Devon
Used to have a C63...
Thanks John
That's the way I did it when I was concerned around warranty, Mobilo and all that jazz.
Routine items at MB, all else at good Indie. (Both CLS and C63 ran superbly after visits to Indie... was much less convinced after trips to MB!
  • Like
Reactions: Cgd
John Laidlaw
Wirral
Land Rover Discovery 4
Thanks John
So you’ve got a dash message for brakes at the moment?
Bit premature with those thicknesses but hey....better to be done before winter. An Indy will also be honest on those which you can’t always rely on a main dealer to be
Rotorhead500
Very South Devon
Cured that generosity for you John! ;)
  • Like
Reactions: Cgd
JBell
Torquey
C350 CDi Estate (GAD Edition)
Computer indicating wear in brake pads, they do look a wee bit on the thin side though (checked whilst swapping wheels). How much have any of yous paid at the MB dealership for this?
I would think about £400, the pads will be £80 to buy and as has been said a good indy will do it for considerably less ££££
You can get prices from MB Grangemouth for OEM pads, they do good forum discount
  • Like
Reactions: Cgd
Cgd
Cgd
C220/16/2.1
  • #47
indeed strange, but i did the visual inspection i didn't take a calliper to it. IMHO i can get a couple of months of that easily, i don't drive the car daily and is usually long drives only!
Cgd
Cgd
C220/16/2.1
  • #48
i'll check the MB Grangemouth, thanks for that JBell :D if you have a direct link that would be grand too!
John Laidlaw
Wirral
You can also call them 01324 686002 parts department Steven Kilgannon is the parts manager, mention the forum for your discount.....
FYI I had a complete set of pads for my 63 for £320.11, so I’d expect yours to be somewhat less:D
Cgd
Cgd
C220/16/2.1
  • #51
fantastic, thanks John Laidlaw
Cgd
Cgd
C220/16/2.1
  • #52
Thanks John
I think I’m almost happy now , been quoted at my indie
£190 generic (front and back fitted)
£250 MB brand (front and back fitted)
I think pretty decent!
Thanks again!
John Laidlaw
Wirral
Thanks John
Thanks again!
That’s quite decent indeed! Well done there
  • Like
Reactions: Cgd
Thanks John
Thanks again!
Keep in mind that an Indie can do the servicing and keep any warranty you may have, intact. (as well as brakes etc)
Neil C1
W203. 2004. C270
does mb grangemouth have a website that has the prices need 2 rear springs and a few other bits but not sure if to go genuine or aftermarket
No, they reply to emails pretty quickly though.
Cgd
Cgd
C220/16/2.1
  • #57
This indie can’t but I’ll definitely look for one that does for the B service
Thanks alexanderfoti
JBell
Torquey
Thanks John
Thanks again!
Decent prices, they are probably exactly the same pads but in different boxes, if the indy uses Pagid pads as an aftermarket option then they will be the same as the MB pads.
You can buy a full set of Pagid pads from ECP for £47 using the code HALLOWEEN80
  • Like
Reactions: Cgd
Cgd
Cgd
C220/16/2.1
  • #59
sadly they are not Pagid JBell, but will definitely start sourcing online for next
