CL500 Electric Problems (Drivers seat, Sunroof)
jwhelancarpentry
London
CL500/2002/5.0-V8
Hello there, i am new to this forum, thought it'll be good to pick the brains of the people who know the car well.
The issues are, the drivers seat.
Basically, i pulled the leaver to let someone in the back, the seat started moving forward, then i pressed on the door card button to pull it forward some more, and nothing happens. Went to put the seat back down, it doesn't slide back to where it was. Nor does the heated/cooled seats work, or any of the controls. I know there's power to the switch on the door, because when you press the bum warmer button, the red light is on when you press it,but when you let go, it goes off.
I am thinking maybe a fuse? I have no idea where to start on this Merc, the wiring is very complex! So thats the main issue, however also a fault with the sunroof.
I press the button for the roof, i can hear a relay ticking when i do so, so might be a mechanical issue? Help please!!
Anyone else experienced anything like this?
Anyone know where the fuses are for the drivers seat?
Thankyou!
Regards, Jim (a merc owner tearing his hair out trying to figure it out!)
jwhelancarpentry
London
CL500/2002/5.0-V8
  • #2
Fixed the seat!
Fixed the seat!
Now its the sunroof? Anyone shed any light? Regards, Jim.
The roof motors have a 3 second stall if the roof is too tight, if you open the roof with the handle provided in the tool kit, you can lubricate the runners with Silicon or PTFE, not WD40 and it should work ok.
jwhelancarpentry
London
CL500/2002/5.0-V8
Hi Malcolm, thankyou for your reply.
I tried opening it manually like you suggested, it tilted fine, but the opening was so so stiff, i cracked it open about 2 inches, and physically could not open it any more, felt like there was an unhealthy amount of resistance. What would you do in my situation?
Kindest Regards
Jim
jwhelancarpentry
London
CL500/2002/5.0-V8
I fixed the seat by just changing the fuse.
Its fuse number 66, under the rear seat (footwell)
It was a 25a fuse that had popped, just replaced it, happy days.
All one can do is to open it a little at a time and spray some PTFE in on to the tracks, in order to remove the cover the roof has to be fully open so that will no help
