CLK W209 Glovebox won't stay shut
J
James99
Kent
CLK 320 (W209 2003)
  • #21
Just wondering, has anyone tried adjusting their latch yet on a 209? Big thanks to Malcolm - googling I found someone say the end trim panel on the diagram Malcolm emailled needs to be prised off, then there is a white wheel inside, reachable with a long flathead screwdriver, which is turned to adjust the latch cable. But I'm yet to open it up to be honest (I hate pulling off trim in case I break something, but will summon up the courage soon!)
All of the end covers are just clipped on the ends of the dash, gently ease away and they pop off
J
James99
Kent
CLK 320 (W209 2003)
  • #23
That's very good to know, thanks Malcolm!
Ease away the front end, as the rear end is held against the door seal
Details sent :D
Sel
CLK W209 270CDI
I think I've got the same problem. The catch on my glove box is loose. It's not obvious how to tighten it as I have a CD player in there. Could you forward the info to me.
Many thanks
Sel
Many thanks
Sel
Welcome to the forum and details sent :lol:
thefast1
Hants
CLK 350 Sport Cab
Hi, New here also, I have the same issue but the glove does not stay shut at all, folded piece of paper wedged in to keep it closed at the moment, could I also get the pdf for a w209 please.
MJBenzCLK
LONDON
CLK 320 W209
Hi Malcom, can you pls send me the PDF too for 209? Thanks mj
takyin80
New Registration
Malcolm,
I have just bought a 55 Clk, the glovebox does not shut unless I push it in so hard.
Please can you forward your notes to me for rectify this problem? Or do I need new part for the latch/lock mechanism on the glovebox cover?
esmail
Malcom,
I have a 55 reg CLK 2.2 cdi and my glovebox handle is broken it only controls one latch inside and doesnt close. aslo the place where it clips onto is lose. any ideas??
T60LAA
hi,can anybody help me please i can not find the answer to this question on the forum thanks tony.
C
Chris123
Hi I have the same problem with having to slam the glove box on my 209.
Could I have a copy of the fix instructions as well please
Many thanks Chris
If I had your Email address then yes :D:D
C
Chris123
Thanks Malcol
Regards
Chris
Both sent Chris,,you can edit out your address
CLK270-CDI
London
Hi there Malcolm,
Could you pleeeaaaseee also send me a copy of the instructions for the W209. I know you're emailing them out, but I can't seem to find the button to email/PM you? :confused: Soz -I'm new to the site!
Cheers,
Gurj.
Hello and welcome,,you will have to pop up your Email address ,you can edit it out when I have sent them
I have sent them to you,,you can edit out the address
