Disabling EGR
W210VIP
W210 2001 E320cdi
Hi! The EGR valve will stay closed and You will have no more further issues with it!Any problems write in here please! Frank
Hi Frank! I’m hoping this will cure my intermittent turbo loss (epic on lockdown).
So I just read you need to disconnect her transducer as well for it to remain closed?
Now my indie says he can egr delete with his computer system. Will this be the same as this post?
Thanks so much.
Frank Mayer
Maidstone,Kent, UK
w210 e320cdi estate automatic 2002
Thanks so much.
Hi!
Noman on earth can do EGR delete on the w210 or on the s210 what so ever! But if You do this type of bypass then You will never have any issue ever till the car is running! No need neither possible delete the egr on the computer system!
Gazwould
C250 CDI
Hi!
What engine ?
W210VIP
W210 2001 E320cdi
Hi!
W210VIP
W210 2001 E320cdi
OM613 I believe.
W210 E320cdi
W210VIP
W210 2001 E320cdi
Ok so I'm getting my circuit together.
However, I don't understand where I connect it too? I know the maf, egr and 12v but where on the cable? So confused. Ive read and read these posts again and again an still don't get it. Sorry.
W210VIP
W210 2001 E320cdi
i did the 210 320cdi today.
connections were...
MAF sensor signal wire = pin24 connector no.4 yellow/white
EGR vacuum transducer power supply = pin37 connector no.3 red/black
EGR vacuum transducer switched earth = pin50 connector no.3 grey/black
before mod, at idle maf sensor voltage = 2.28 egr closed / 2.02 egr open
after mod, at idle modified maf sensor voltage = 2.28 'egr closed' / 2.00 'egr open'
the car drives well and logs no faults, all in all seems to work very well indeed.
Do you have to cut all these wires and then connect the mod to the wires going to ecu?
Or do you just peel back the insulation at the wires and install/solder the shunt to dedicated locations?
Gazwould
C250 CDI
Because there are several advantages to just one disadvantage .
W210VIP
W210 2001 E320cdi
Anyone? Please help :)
umblecumbuz
Wales and Gozo
Here:
AMF Automotive Ltd
Unit 5, Oakview Industrial Estate, Horton Kirby, Dartford DA4 9DF
020 3384 4644
W210VIP
W210 2001 E320cdi
Thanks Guys!
I would ever feel so guilty and rude calling him up just for this!!
Me: um hello I saw you on the forums...
Alex: your call has been ended
Naraic
2005 CL500.
Hi!
I did an EGR delete on my E320cdi w210...have I missed something?
