Disabling the immobiliser
OK we now know that your car was built 1996 December, I will post back
Tables with structure VIN for Mercedes-Benz VIN of cars Mercedes-Benz
VIN check the other cars in this group of companies VIN of cars Mercedes-Benz com
Main data
Parameter Value
Ident. number (FIN) WDB2100171A324600
Baumuster 210017
Sales name E 290 TURBODIESEL
Permanent link http://carinfo.kiev.ua/cars/vin/mercedes/vin_check?su=z85fg5j
Order number 0 6 569 65728
Delivery date 1996-12-16
PAINT1 269U
Interior color 101A
Engine 602982 12 011422
Gearbox 722613 00 223585
Lights units HELLA
Class 1
General data for model code 210017
Baumuster Модель Платформа Модель Двигатель КП Кол-во дверей Date From Date To
210017 E-class W210 E290 Turbodiesel Дизель
602.982 АКП
722.605
722.613
602.982 МКП
717.460
717.466
SA codes
Code Value
101A MB-TEX BLACK
236 SPECIAL LAMP SWITCHING - DAYTIME RUNNING LAMPS
248 REAR SEAT WITH INTEGRATED CHILD SEAT
269U TOURMALINE GREEN METALLIC
423 5-SPEED AUTOMATIC TRANSMISSION
431 3-POINT SEAT BELT REAR CENTER
450 TAXI - INTERNATIONAL
533 SPEAKERS FRONT AND REAR - WITHOUT RADIO
580 AIR CONDITIONER
600 HEADLAMPS - CLEANING EQUIPMENT
630 ECE - WARNING TRIANGLE
668 PACKAGING FOR SHIPPING VEHICLES WITH TIE-DOWN HOOK
673 HIGH-CAPACITY BATTERY
807 AEJ 06/1/M/X
825 VEHICLES FOR SWEDEN, ADDITIONAL PARTS
873 SEAT HEATER FOR LEFT AND RIGHT FRONT SEATS
984 COC DOC., DELETION OF VEHICLE REGISTRATION DOC.
SA numbers
Group Codes
01 01 12328/89/ 01 12443/49/
03 03 12444/36/
07 07 12443/49/ 07 12444/36/
13 13 12328/89/ 13 12443/49/
14 14 12328/89/
15 15 12328/89/ 15 12443/49/ 15 12444/36/
18 18 12443/49/
20 20 12328/89/ 20 12443/49/
24 24 14094/19/
26 26 14055/44/ 26 14062/13/
27 27 14094/19/
29 29 14039/24/
32 32 14029/06/
35 35 14056/65/
41 41 14202/23/
46 46 14048/20/
49 49 14114/05/
50 50 14160/03/ 50 14180/07/
54 54 14020/03/ 54 14048/20/ 54 14097/02/ 54 14098/06/ 54 14152/10/ 54 14170/02/
58 58 57206/06/
68 68 57513/01/ 68 57675/03/
72 72 57542/02/ 72 57542/04/ 72 57542/06/ 72 57542/10/ 72 57739/71/ 72 57739/72/
73 73 57542/02/ 73 57542/04/ 73 57542/06/ 73 57542/10/ 73 57575/08/
82 82 14097/02/ 82 57505/08/ 82 57542/02/ 82 57542/04/ 82 57542/06/ 82 57542/10/ 82 57548/03/ 82 57721/01/ 82 57721/07/ 82 57722/01/ 82 57723/01/ 82 57723/08/ 82 57724/01/
83 83 57516/05/ 83 57558/11/
86 86 57718/03/
88 88 57550/34/ 88 57550/35/ 88 57550/55/
Not easy at all, we know that the remote amp could fail on these early cars, but the key would still turn in the ignition. Doe the LED in the end of the key flash when pressed. To sync this key, press the large button twice and place in ignition switch within 15 seconds.
Is the key sending a beam that can be seen in a camera
jimatron
Staffordshire, England
1989 230E 2.3L 8 valve. 39,000 miles from new!
Newbie here.
My 1989 W124 230e has a start up problem. I have ignition lights but it doesn't turn over. Only have 1 key which isn't the original also never had a key fob so i have no idea if it came with 1 as new.
I was recently told it has an immobiliser which may be causing problems.
Any Information on disabling this would be much appreciated.
RPelli
Sweden, Vaestra Goetaland
MB E290TD -97 (W210)
Hi JIMATRON!
Sad to say I haven't been able to resolve my issue yet, so unfortunately I can't be of much assistance.
Hope you'll be able to find a solution!
whitneywoo
manchester UK
c220
Hello first time I have posted on here I have looked at all the posts but none have the same fault as mine well I don’t think they have. The Red and green light on the mirror do what they should I think they go off when I push the button on the key. They car starts then stops I can hear the fuel pump click in. Tomorrow I am going to re solder the OVP relay and disconnect the immobilizer (it has the silver sticker in the window) and the wiring loom looks good from what I can see is there anything else I should be looking at ?
This does sound different if the engine starts and stops, an engine fault maybe
whitneywoo
manchester UK
c220
Well I disconnected the immobilizer and re soldered the OVP relay and checked the loom and the car will not start I took the cover of the Fuel pump relay and it did pull in on cranking I then held the contacts on the solenoid and it started to run so I turned it off and it started fine so I thought I had fixed it then it started to run on 2 cylinders so I turned it off and started it again and I was fine left it ticking over and it cut out and back to where I was before I did anything I feel it could be fuel pressure but when the engine cuts out I can hear the fuel pump drop out and few seconds after it engine stops running if it was a crank sensor I feel it would not start at all. I did run it with the MAF unplugged and it made no difference Thanks for any help you guys might have sorry if I am going off topic and should be in another thread
Sounding like the crank shaft sensor
whitneywoo
manchester UK
c220
Thanks for your reply if it had faulty Crank sensor do you think it would fire and run for a few seconds? I will fit on anyway and let you know
thanks again for replying
W210 E230
London
E class w210 2.3 1996
Did u manage to disable the immobiliser by an
I had cause many years ago to call upon Mobilo to get my car (W202 C180) going after the immobiliser refused to let go of my car. The car unlocked and locked fine but inserting the key and turning did nothing.
When the chap from mobilo came out he quickly disabled the immobiliser which shocked me when I saw how simple it was. It takes about 5 minutes thats all.
I'll PM you the solution.
EDIT: Cant send you a PM as they are not enabled for you. Send me an email to sales@comand.co.uk and i'll reply with the solution.
Did you mange to disable to immobiliser ive gor the same problem and aslo cant start the car
Hastings sussex
1996 Mercedes s320 lwb
Did anyone solve this problem ???....I have a 1996 s320 lwb and my immobiliser is stuck on....please help
enzo09
mercedes benz w202 c200 1997
newbie here
i have a w202 c200 lost my key transponder thingy and its causing a heafty penny to get another is there anywhere to bypass the system to be able to start the vehicle... really need help anyone
Hello and welcome,
Probably not going to get too much of a response because we’ve no idea if you’re the legal owner... o_O
enzo09
Hello and welcome,
im from trinidad and tobago bought the vehicle and after 2 months lost the keys its costing me alot of money to get the transponder key thing and them these guys is charging alot to program it looking for a simple fix
enzo09
if not i will have to change the engine a mechanic suggested
Changing the engine won't fix it.
I would suggest you get a local auto electrician to look at it.
enzo09
I would suggest you get a local auto electrician to look at it.[/QU
went to the dealer and its costing over 12 thousand tt to get a transponder key and to reprogram
enzo09
but if theres nothing that can be done thank you all so much for your help
The w202 often had aftermarket immobilisers fitted. Factory immobilisers tend to be integrated to the key.
You suggest you have a separate immobiliser fob which would suggest it wasn't factory fitted.
enzo09
an auto electrician tried and he got it to tumble but it wont start and he told me its ths immobiliser thats giving trouble..thus the story of the dealer and the cost to fix but when i was reading through the forums to see if it could have been anything else that was causing the issue found that someone knew a bypass and i wanted to know to be able to fix my vehicle
