Ross Thomas0000
- Jan 4, 2020
- Mercades clk 230 supercharge kommpressor softtop year2000
This is as it should be, with ignition off you can operate the windows if you open a door. Once a door is closed, only be turning on the ignition will you be able to operate the windows.
I also have same problem can u bypass immobiliser ??did you have any luck with disabling the immo? i have same problem on my fathers 95 c220d
