E320 Cdi Avantgarde 2006 Airmatic Relay location
schtii
E320/2005/W211
Hi all,
I am having a huge struggle locating the Airmatic Relay on my E320 Cdi.
Hours trawling relay maps and relay info/videos leads me to a discrepancy in what my actual fuse box shows.
In short: My rear suspension has dropped. I have ascertained that no power is getting to the compressor. I recently replaced the compressor due to a previous failure and wondering if that particular issue lead to the eventual failure of the relay. Before i try to diagnose further, a replacement of the relay is my next port of call.... If i can find it ;)
In the second image, I'm wondering if its one of the 2 relays sat right under the windscreen although I'm yet to be able to remove them?
Fuse maps indicate the relay is in Slot "S" but i cannot find that.
Any help will be much appreciated.
AMGeed
Poole, Dorset
S204 C180K
Welcome to the forum.
You are correct in that the relay is market "S" in the diagram below. 20230301_195709(0)[1].jpg
schtii
E320/2005/W211
You are correct in that the relay is market "S" in the diagram below. View attachment 82395
Thanks for your reply. Thats my issue - my fuse box does not have that "S" relay. I cannot find a diagram that exactly matches my fuse box.
AMGeed
Poole, Dorset
S204 C180K
Have you got a Mercedes specialist nearby?
They can probably point out the location of the relay and swap in over for you.
Snake Charmer
S211 E320 CDI 2004
I had the same problem trying to replace the relay on my S211 supplied with the new compressor, this has jogged my memory to solve where it is!
