Eco 0n CLA 250 Start-Stop rarely works
springbk
Milton Keynes
CLA 250 AMG Line 4MATIC Shooting Brake 2015
I have a 2015 250 CLA AMG Line and I have noticed that my Eco Stop Start rarely works. Now I know I do not drive very far every day but when I first got the car it worked on 90% of my journeys even my short ones. Now even after a 100 mile journey it does not always work. Wondering if the battery needs replacing or is there something else I should look at and If I do change that battery do I do both? I have also noticed that if I stop and then restart the car a few times from time to time this will bring it back on.
Gazwould
C250 CDI
Excellent news , leave it as it is .
Using the diag tools, we can identify what is preventing the car from entering stop start mode. Its most commonly the battery, but there are 20+ parameters that must be met.
springbk
Milton Keynes
Thanks for this information, You are a little out of my way, Tonbridge vs Milton Keynes. Probably start with replacing the battery and then I think I will go see my local non MB garage....
Yeah, that is a fair trek! There are a few indies close by to you I believe.
They will need MB Xentry diagonistics to check the cause.
malcolm E53 AMG
You are right the battery needs to be healthy 12.6 volts (engine off) for the Stop/Start to function. I hate the system but it does act as a good battery indicator. I changed my original AGM battery early this year and the Stop/Start operates within a distance of 1 mile in this warm weather where prior to this it wasn’t operating at all
springbk
Milton Keynes
Thanks. Yes there is one that I like to use, namely Autoclass. Just out of interest, what does the AUX Battery do? Does this affect the use of of Auto Stop/Start?
CowleyStJames
Oxford
Mercedes-Benz E63s, Old knackered G wagon
I've just replaced my AGM stop/start battery last week in my E Class.
Don't bother trying to charge it, they're so small that you'd be wasting your time.
I tried charging mine a couple of times on the AGM setting on my Ctek charger, but the next day I had Auxiliary Battery Malfunction come back up.
Buy a new one, 15 minutes to change and mine was a Yuasa
OEM copy for £36.
Even the original captive bolts just screwed straight in
The aux battery does the stop/start
