Engine cutting, voltage hitting 15v
Oconnell123
C180 2012
Hey there, hoping yku could help;
Mercedes c180 2012 blue efficiency - auto
Faults are; on take off after starting engine "parking release break" warnings appears, then "front left malfunction, consult workshop" "front right malfunction, consult workshop", engine will sometimes go into limp mode after this. Other times the engine cuts whilst accelerating.
Alternator has been replaced.
Could this be caused by a faulty batter? I have just noticed in its previous service history that it failed a battery load test.
Thanks!
O
Oconnell123
C180 2012
  • #2
Thanks!
Forgot to mention, the car was reaching 15volts whilst idling
Kev555
N.I
You would need a proper Mercedes star diagnostic done to get the proper fault codes as the ones you've posted sound generic from an OBD reader. A poor battery will put lights and fault codes on like a Christmas tree. Also check electrics for water ingress. If battery is gone get it replaced as it will need to be before you fork out money for a diagnostic session if needed. Some of the Merc techs might answer later with previous knowledge of what you are describing. Always better to replace the cheapest parts and the ones you know are definitely faulty to start with.
ajlsl600
france
Regulator or wiring.
mioba
Nottingham and Köln
15v is a tad high, was it aftermatket alty, could be frying your battery
Uncle Benz
West Sussex
Mainly Mercedes
Link to one I had a little trouble with
