Excessive oil consumption of CLK55 AMG
WG M-B
North west london
C63 Wagon in black
I have leaking rear main oil seal on my 55 engine in my C43, would my M113 V8 have the same set up, the engine was originally from a MY 2000 208 CLK.
If so would cleaning this gallery add much labour time when replacing the seal?
No it wil add about fifteen minutes.
frejo
Gothenburg
AMG C55T -05
I may also have this problem since the car uses a bit more oil than usual. Is it just a cleaning of the gallery, or do you have to do some major repairs?
jberks
3 litres is an awful lot. Surely theres a trace somewhere. A leak would be blindingly obvious and burning that amount would surely show up in the exhaust and the plugs?
frejo
Gothenburg
AMG C55T -05
How much oil are you consuming??????
Perhaps 1 liter every 1500 miles. Strange thing is that after a service the oil level, on the instrument, is OK for the first 4000-5000 miles and then it seems to need oil every other 1000-1500 miles. First thing I'm going to do is to make sure that the oil level sensor is OK, but I am a little worried that there might be something wrong...
(I hope I converted correctly to miles since we're using kilometers in Sweden, so the engine needs perhaps one liter every other 1500-2000 km)
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
I,m sure I have read somewhere, that upto a litre of oil every 1,000 miles is considered normal for a M113 V8 Engine, IIRC this was from a Mercedes document though I,m b***ered if I can remember where.
eihtur
Mercedes C180k 3door
We have a Beetle...in the handbook it says up to 1 litre per 1000kms is acceptable!!!
WG M-B
North west london
C63 Wagon in black
I would consider 1 litre over a thousand miles perfectly fine
B
baz.purdue
Yeovil
CLK55 AMG 2003
  • #30
Try a litre every 100 miles! It's a killer
frejo
Gothenburg
AMG C55T -05
I'm sorry to hear this, hope you'll be able to solve it.
I thank the rest of you for the answers and I will go on not worrying about my oil consumtion.
/frejo
B
baz.purdue
Yeovil
CLK55 AMG 2003
  • #32
Breathing Gallery
These symptoms are very similar to a couple of cars we have seen in the last year with the breathing gallery behind the crank seal casing is blocked.
But obviously over filled oil will do the same :D
I would say you have a pretty deep puddle in the inlet manifold looking at those plugs
So is there anyway to check the breathing gallery other than removing the geakbox.....as much as that is cheaper than having the piston rings replaced, if it isnt that its still £400 i could have saved toward it!
Many thanks as always!
WG M-B
North west london
C63 Wagon in black
I would pop the top off the inlet manifold to see if it's swimming in oil first
