Glass cleaning
McDonald
Surrey
SL500 2004
My R230 has a section of glass on either side of the rear window. It seems to have some surface material that's deteriorated - as though a tint was once applied and has worn away over the years. It's the only thing marring a very clean, shiny car.
I've read elsewhere on the forum that glass can benefit from the use of clay, but would like some reassurance / confirmation before I make an almighty mess.
Those are known to deteriorate, its the coating of the metal panels.
Most people get them wrapped in black and they look new again.
Let's have a pic buddy . Is it the same as the frosting on old headlights ?
Chrishazle
Nr Ashford, Kent
The grade of wire wool you would use is Grade 0000 - I used to use it to apply wax to a solid mahogany dining table (following the instructions on the tin of wax!), it does not scratch, and the table top had a mirror-like finish!
Craiglxviii
Cambs UK
I just bought some 0000grade (jeweller’s grade) from Amazon. A big hank of it for £5... specifically to clean my windscreen.
Using a clay bar on glass won’t damage it at all.
drmw
Yorkshire
www.autonomed.co.uk
DON'T - they are plastic & the black finish is on the inside.
You can try wrapping, but my own direct experience led to getting them changed (sun light caused blisters)
Chrishazle
Nr Ashford, Kent
If it's a plastic like the rear window of my 968 cab, that was pretty cloudy when I bought the car, there are special cleaners available to remove the cloudiness. The one I have is Renovo window polish which I have not yet tried as I need to do the inside of the window, and with the wind deflector in place it would be rather awkward to access. I did the outside with AG Bodyshop paint renovation fluid, the very fine 2000 grit variety (NLA unfortunately) and that removed a lot of the cloudiness.
drmw
Yorkshire
www.autonomed.co.uk
The black is on the inside & it comes away, not cloudy
McDonald
McDonald
Surrey
SL500 2004
I couldn't quite work out how to add text & photos, but my window problem is illustrated above.
McDonald
McDonald
Surrey
SL500 2004
Well, it looks and feels like glass but I could be mistaken. I assume there are other SL owners with the same arrangement and more knowledge than I have. It disfigures the car somewhat and I'd like to take remedial action. I'm still not sure how to approach it.
DREAMER NO2
W124 2.6E M103 1989
MCDonald Good luck i took it that the part in question was glass .And my fix stands for glass ,,but not sure about other material . I used to work for a Mc Donald at BSR .
McDonald
McDonald
Surrey
SL500 2004
Thanks Dreamer, I still believe it's glass but I'm hoping someone with hard information will confirm it.
My name is unusual because it's my first name. I do have happy memories of Kidderminster, I was married there 30 yrs ago.
Mic
Oxfordshire
www.bennettgibbons.co.uk
DRMW's Post no.7 is the answer to that issue. Looks like someone has tried to "clean" and made a worse mess than they started with.
Mic
McDonald
McDonald
Surrey
SL500 2004
  • #17
Thanks for the replies. I guess replacement is the only solution.
McDonald
McDonald
Surrey
SL500 2004
  • #19
DRMW suggests that wrapping wouldn't be a lasting solution (sunlight causes blisters). It strikes me that if I'm reconciled to replacement and if the parts are available, I could try cleaning first before splashing the cash.
JBell
Torquey
C350 CDi Estate (GAD Edition)
That won't clean, the finish is gone, a good wrap should last 5 years, you could do it yourself for £20
