Heater booster fault code; S211.222
Oddih
Norway
S211/2006/E320 CDI
Have a S211.222, E320 CDI, 2006.
There is a fault code on the Heater booster:
It is not active, but it reappears after reset.
Could it be connected to that the battery went low and I haven't recharged it properly after that?
mersum1es
Finland
No. You heater booster is malfunctioning (it is built 3/6 heater elements depending on age, some of the elements gone bad).
O
Oddih
Norway
S211/2006/E320 CDI
Thank you for the reply.
Is it true that I have to remove the whole dashboard and dismantle the heating system to get to the element?
mersum1es
Finland
Yes, unfortunately. BUT if you are not having current leak and get at some heat fron vents I wouldn't bother... Do you have aux heater (Webasto) fitted?
O
Oddih
Norway
S211/2006/E320 CDI
Yes, fortunately I have a Webasto:)
